MPU6050 Accelerometer Gyro Temperature icon MPU6050 Accelerometer Gyro Temperature — Reads MPU6050 gyro, accelerometer and temperature via I2C, initializes and returns data on-demand to EZ-Script variables using ControlCommand RunOnce Try it →
Thanks DJ.   How Do I creat the pause frame or is it already created in AutoPosition.  I have read the autuposition tutorial several times.
I did get the my robot to act nice by using delay, steps and speed but if the correct way is a pause frame I want to use it.
Hi Ellis,
To answer your question about how to add a pause between frames; Look inside the AutoPosition Control you are using to make your actions by clicking on the Gear Icon. Then click on the Actions tab. In the center window called Frames you should see a Pause already listed there. Just double click on it and it will be added in the right window to the end of the Action that you have selected from the left window called Actions. If you want to adjust the pause time just highlight the pause in the right window and click on the edit button to the right of this window.
Hope this helps.
Yes that really helps. Thanks for everything.
Thanks for all the help.
