ESP32_MPU6050 icon ESP32_MPU6050 — ESP32/Arduino EZB firmware with MPU6050 support: provides accelerometer angles and Yaw/Pitch/Roll gimbal servo values for stabilization and scripting Try it →
#385
REX it looks very good,cant wait to get my hands on it,cost to me doesnt matter
AS i buy every type of sensor made to test and compare to my others,mostly do it for my projects
BUT i can share my results to others
#386
Also REX did you do any other work on your beacon circuit,i got all my parts in and collected data off the pololu ir beacon ,but wont be able to make it till i get back from my work trip
#387
I am still collecting parts. Unfortunately I don't have a lot of extra cash at the moment. Everything is going into getting the rental house ready for the new tenants to move in. Having to maintain my home plus two rental homes and also working at a power plant, I don't get much "me" time. tired
But I refuse to give up on my robot! I will find a way...
#388
WIH my work in china keeps me from working on robots ,but good news NO MORE WORK after 3 weeks i cant wait to only work on robot
In 3 weeks there will be so my photos up of my designs and more money i have more then i will ever need,so i just have to wait
#389
I loved the discussion between Rich and Robotmaker about cost efficiency : two different philosophies at stake here, between the British (and so European) way to look at things and the US way. Both ways were capable to build empires and both lead to results. One way, though, brings more grey matter in the equation for the same individual, while the other way needs to compile more logistic, which allows to more individuals to reach the same goal. I'm just considering setting up a self docking process of my own... but in this story, I'm the French guy : both ways (using pre-set expensive devices or working on a script with QR and basic sensors) I failed so far... As a famous French writer, Voltaire, said once, (sorry for the Google Translate) : The French arrive late to everything, but they finally arrive!
#390
You are probably the only person to have ever used the word loved along with the phrase discussion between Rich and Robotmaker... Let's not go there again though:)
I'm glad you posted on this topic though, this item has made it's way back up my never ending list and I will be hitting it again soon. You saved me the trouble of searching for it:)
#391
RICH and me will never fight any more and doing a lot better now. AT least with my posts we are getting better.
RICH here is a idea for you instead of searching for a post save as a link on your desktop like i do.
#392
this one works as soon as the robot is not too far from the glyph hanging above the charging station, which is a docking station from Neato XV 21.
I'm however facing a lot of obstacles regarding doing anything more complex than this and any help would be appreciated. For example I can hardly move then check for the presence of another glyph arround (so I could move from room to room) because the variable $cameratrackingtype="glyph" and all other variables regarding this such as $cameraistracking send always the value "true" while not in view of the glyph anymore.
I posted about this issue and many others here :
synthiam.com/Community/Questions/8223
if someone could at least tell me how to make my robot capable to "forget" the previous object, that would be just awesome : the ControlCommand ControlCommand("Camera", CameraClearLastGyph) doesn't seem to work.
Thanks in advance.
