Avatar JD icon Avatar JD — 3D Avatar JD simulator with bidirectional servo sync, action sequencing, $SIM_ scripting, EZ-B emulator support and pose/movement visualization Try it →
Italy
Automatically Connect To A Port
Hello.
I would like my Visual Basic program to automatically connect to Ezboard when i launch the program. Ezboard connection is on COM port 3 on my pc, so i have written the code:
Sub Form1 load Ezb_Connect1.Connect(3.0) ...but it does not work
So i have tried Ezb_Connect1.Connect(3) ...but it does not work
Can you help to solve the question, please? Thank you.
Use create a shortcut tool and in it you can specify a script to run when you open it.
OR
You can create a windows batch file like this Start "C:\Program Files (x86)\EZ-Robot Inc\ARC.quot; "C:\Program Files (x86)\EZ-Robot Inc\ARC.ARC.exe" "C:\Users\Technopro\Documents\ARC.Jarvis Ph. 1.EZB" "Auto start script"
The bold part is the spot where you saved the .ezb project. "Auto start script" is the script I told it to run when it opens.
Change this to fit what script it will run and in that script put your connect command.
He is asking about the SDK and VB not ARC. Which very few use so an answer may not come (sorry, i can't help there).
However @technopro, avoid batch files, they are old hat and messy - I've covered it in an old post somewhere, use AHK for a much cleaner method if you even need to pass additional commands, your example would only need to use the link from shortcut creator, there's no sense in using anything else to be honest.
thanks for the heads up rich.
(playing with autohotkey now:) )
Edit: sick
Italy
And how can i auto-conect i visual basic when the form load?
I have tried
Use "com3" not 3
Italy
Thank you, but if i write
Ezb_Connect1.Connect("com3")
I have the error "InvalidcastException" "Invalid cast string com3 type boolean"
if i write
Ezb_Connect1.Connect(com3)
I have the error "com3 not declared"
What am i wronging? Maybe i have to dim com3?
Italy
Can you help me, DjSures?
