edit* Going to repost later.
Redzone
— Edited
Vader Sentiment Analysis
— VADER sentiment analyzer for ARC returns positive, neutral, negative percents and a compound score from text; enables emotion-driven behaviors.
I will have a look to night after work, don't have time right now. Here is the code right now, I cleaned it up a bit so it reflects the correct "if" statements, however, I have not modified it back to the original yet. I wanted to get the basics working before assigning the Side pings Left and Right statements so it will not zig zagging while moving as you pointed out. Thank you.
I have run a few tests and thought about the various conditions in the main If-ElseIf code. Given the last two ElseIf statements, it may be advantageous to use "and" conditionals in the first ElseIf statement after all. This is because it may be best to not stop and reverse if just one of the front facing sensors detects something. Such would be the case if "or" conditionals are used in that first ElseIf instead of "and". Because the next two ElseIf conditions use the condition in which just 1 or two of the base sensors detect something. As I mentioned in my last post, those ElseIf conditions take care of the situation in which there is an obstacle to the right or left of the unit. They cause the robot o turn one way or the other to avoid it. The first ElseIf, however, should probably take care of the situation in which there is a total blockage just ahead of the robot (like a wall). For that to be detected, all 3 Base Sensors should be less than 45. For that to be the case, there should only be "and" conditionals in that first ElseIf statement.
Now here is the problem with the robot's actions in relationship to that first ElseIf. What happens now is the robot simply reverses. I'm assuming it reverses enough so that the Ping reading will be greater than 45. Once it does that, the script will check the Ping State of the sensors and see that it is clear. That will cause the robot to move forward since the first If condition will be met (all 3 Base sensors > 45). And it will move forward until it gets close enough to the obstacle for the readings to go below 45 and the whole thing will repeat again. And again, and again, etc.
So there will need to be more code associated with the :Reverse Goto label lines of code. For instance, it could try to go around or it could turn completely around and go the other way or go 90 degrees and try that, etc. All sorts of possibilities. Depends on what you want it to do in that situation.
Likewise the last 2 ElseIf conditions do nothing but turn. If the 3 Base Sensors are clear after the robot turns, it will go forward from that point; whatever way it is turned. It will not go back to the direction it was going before the turn. For that you will need to add more code to the :AlarmL and :AlarmR goto code lines.
One of the things to keep in mind with If-ElseIf statements is that once one of the conditions is met, none of the rest of the possibilities will be checked. So, even if other possibilities might also be "True" nothing will happen because of that for that execution of the IF-ElseIf code loop.
So in summation, If you want the first ElseIf condition to execute only when all 3 forward pointing Base Sensors detect an obstacle, use "and" conditionals in it, not "or". The last 2 can be like they were originally with a combination of "or" and "and" conditionals. Think about what you want the robot to do for each of the ElseIf conditions. It might also be advantageous to have the robot say something more specific when it speaks. For example, instead of saying just "Object Detected" when it turns right, it could say "Object detected on left, turning right".
Feel free to ask questions.
@WBS00001,
Been working to many hours lately, tonight I have a few hours so below is what I've changed. It seems to work pretty good. I have not field tested yet and still have a few more things to add. The base is lifted up so the wheels turn but can not move. I plan to use the reverse for the dropoff code, just have not finished this yet. Please have a look and any other suggestion will be much appreciated.
Cheers,
Hey merne, did you get it all working OK? Here's my script I use for object avoidance; it is based on the tutorial that Rich did, that I mentioned in post #2.
hey bob, I did get it working and it seems to work good, the only thing is the slow response to detect an object. I think the bumper sensors that toymaker and D.cochran are using would be a lot better and faster, but I do not have any info on that. If I knew how to program an Arduino I would use them with the EZB. I have not given up on the Arduino yet. I see that budel0 has made great progress on his navigation program and hope he share with the community when he completes it.
Cheers,
@merne I finally got a chance to give the script a look over and it seems to be fine. The only minor error I saw was the spelling of SayWait in the Reverse section. Functionally it looks okay. Hard to say why it is slow responding. It's possible the channel is being flooded and it is missing readings.
The script is going to spend most of it's time reading the sensors. Checking the If-ElseIf section takes practically no time by comparison so it's almost as if it is in a loop, simply going through the sensor checks again and again only. This often leads to channel flooding. Although it seems counter intuitive, adding a bit of a delay in the loop could actually help the situation. Perhaps a sleep statement just before it checks the sensors. Not too much, 100ms maybe to start with. Another way that could be even better is a smaller sleep between each sensor's check, maybe 10 or 20ms each. That should definitely help prevent channel flooding.
In addition to the sensor checks, there is the Forward() command being sent again and again when it is going forward with no obstacles in front of it. It would be best to not send it every time. You could do this with the introduction of another variable to keep track of the motion state. For Instance, something like:
That way it only sends the Forward command once. Of course, if you wish it to say the phrase "No Objects Detected continuing forward" every time through the loop, you would have to move the Say statement outside of the If statement. But, if you do that, having it send the data for that Say statement every time through the loop can also help lead to channel flooding. It may not in this case, however, since "Say" sends the data to the PC and not to the robot.
Finally, in the other Goto sections, set the $CurrentMotion variable to some appropriate state depending on which label the script went to so as to keep track of the units current motion state. Such a variable can be handy for making other decisions as well.
Another possibility is the reliability of the sensor's return echo. But the solution to that could cause unacceptable delay in itself, so I won't go into detail right now. Such a thing would most likely show up in unexpected motions of the robot. Turning or stopping when the way is clear.
Good luck!
