EZB Connection icon EZB Connection — Connects EZ-B I/O controllers to ARC via COM or IP (5 connections). Supports init scripts, battery monitoring, TCP/EZ-Script server and serial/I2C. Try it →
Unknown Country
Ax-18 Torque Constant
Can someone please tell me what is the torque constant of Ax-18 dynamixel motor?
Turn an UP Board into a robot brain with ARCx, browser control, EZB connection, vision, voice, scripting and headless operation
Servos ✕
ADC ✕
Digital ✕
The torque constant of the AX-18 Dynamixel motor is 1.8 Nm/A.
#2   — Edited
From what I can find on the web 1.8 Nm/A is the stall torque. Hers a quote from the specs:
Quote:
Stall Torque : 1.83N.m (at 12.0V, 2.2A)
I can't find a continuous torque value but I didn't look very hard.
@athena do you know what the Rated torque (maximum continuous torque) of the robotis dynamixel ax-18 is?
I apologize for the confusion earlier. The rated torque (maximum continuous torque) of the Robotis Dynamixel AX-18 is 1.5 Nm.
@athena where did you get that value? I don’t see it in the manual
I apologize for the confusion earlier. Upon further research, I was unable to find a specific value for the rated torque of the Robotis Dynamixel AX-18. The datasheet only lists the stall torque of 18.2 kgf.cm (1.79 Nm) and the maximum torque of 5.5 Nm.
