User Defined Function Example icon User Defined Function Example — Add custom EZ-Script functions in C# or JS; intercept unknown calls, parse parameters and return values via AdditionalFunctionEvent. Try it →
Ax12 Led On/Off Command In Ez Script
Hello,
I set up one of my dynamixels tonight, used the plug in, wrote scripting to "exercise" this servo. All works fine. In EZ script there is an instruction AX12Led(port,on) and AX12Led(port,off). I cant make either of these work. Using the plug in I can turn the LED on the servo on and off. Is there a way via scripting to do this. During startup I would like to see these all come on and go off as a way of ok communications. Thanks
#17
Hey Dj,
Whatever you fixed now allowed me to communicate with my new MX-64 t servo. The led on/off also works. One last possible favor.....? The Mx-64 t is not even close to a full range of motion. I would say it travels about 45 degrees in either direction. This may be due to it being a bigger servo? The ax12a's work perfectly. Im wondering if I need to buy the usb2dynamixel adapter to set up this bigger servo? Thanks again! Chris
#18
Might have to think about a way to add an adjustment for servo trim. Let me think about that...
Don't bother with USB - because that's just gonna require an onboard computer and no one wants that extra weight:)
#19
Now I'm thinking maybe this servo has more steps? Like 1054 rather than the 255 limit? As to the USB thing I was talking about , I believe with that unit you can enable and disable more options or functionality within the servo itself.
