That's not good if the batteries are getting hot. that means they are either worn out or there is a short in the connector, perhaps. I would stop using those batteries if they are getting hot. That is a clear sign of danger. Common sense is encouraged for items getting hot that shouldn't. Such as batteries. Be careful!
thank you for the warning and explanation.
