Dual Hbridge W/PWM icon Dual Hbridge W/PWM — Dual H-Bridge w/PWM movement panel: control two DC motors' direction and speed via EZ-B PWM for responsive forward/reverse/turning. Try it →
Batterie Safety
Batterie Safety
wel i had a bad week with batts.so i wanted to tell my experiants. the batts we use here has a sort seal ( stamp ) that warns you , for excample is bad or worn out.on one side is a sort off sticker, and it has little wires behind who you cant see when the bat is good. but when the batt is swelling the seal ( stamp ) expand and the, little wires become exposed.that tells you not to use that batt, anymore,the batt becomes dangerous.
That is correct. Great job nomad. These details are also presented on the battery tutorial page, which can be found here: https://synthiam.com/Tutorials/Lesson/26
The terms of use for ARC and mobile app explains the same details and directs users to the tutorial page for additional information. There are photos of a swollen/puffy battery for comparison on the tutorial page as well.
isaw the tutorial but not the little wires
