Hugging Face icon Hugging Face — Connects your robot camera to Hugging Face AI models for vision chat, object tracking, classification, captioning, and autonomous movement. Try it →
Batteries (Noob)
I have the wild thumper 4WD chassis.
I read somewhere that anything over 5V is a waste for the EZ-B. Not sure this is true...
IF this IS true, should I have two battery packs? 6V for EZ-B and a higher voltage, higher AH battery for the chassis?
I'm looking for the best solution, not the cheapest.
Can anyone recommend a link to buy the best battery pack?
Which chemistry do you recommend? I would prefer to avoid anything that is finicky as I can be hard on batteries.;)
Welcome @mcbaker01
The EZ-B needs 6v to support internal operation, but it's on-board regulators can handle up to 18v so there is no problem using a 12v automotive type battery for large projects. The "waste" is referring to the nature of the voltage regulator (excess voltage is dissipated as heat)... this is normal and not limited to the EZ-B. There is math involved as to how much battery capacity is reduced through regulation... but in my experience it is negligible at worst.
Dual battery's are an option for use wherein one device needs higher voltage then another and one does not want to use, or put excess loads, on a voltage regulator or step-down transformer option, but introduce the need for multiple charging solutions.
Battery chemistry is somewhat subjective at the beginning stage... RC type batteries are common and compact. Lead acid types may be better suited for heavy duty use, of which an AGM (Absorbed Glass Mat) type is best for a non-spillable solution on a mobile platform.
As you learn and experience, then you will find your own preference for differing applications. But the most important to remember is matching the charging requirements to the battery type to ensure safety and long battery life... next will be a balance between weight, cost, capacity and current draw for your particular application.
My current robot platform uses a small AGM 12v battery for ease of charging, lower cost and high voltage/current for the drive train I am running. The battery weight also acts to provide a low center of gravity for stability. I don't have any links, but you could check out a hobby store for 7.4v RC LiPo battery and charger combo that might work best for your Wild Thumper 4WD chassis.
Don't forget that you need a H-Bridge motor controller to link the EZ-B and the drive train, do NOT try to drive the motors directly off the EZ-B!
Other members will also have experience they will share with you.
Keep us updated:)
Great, thanks so much for the advice.
I could have sworn that DJ said you need on H-Bridge per axle.
Is this not correct?
I suspect that it depends on the current capacity of the H-Bridge and the total needs of the motors linked in parallel.
With the little 2.5amp controller, then one per axle (three on that unit EDIT: two on the 4WD) might be required. Each H-Bridge would run the left and right motor for that axle and you just wire each H-Bridge's input wires together in parallel to the EZ-B so they act as one.
Alliteratively, a larger controller could handle all three motors per side in parallel.
@ everyone No guys , for 6wd thumper three l298n h bridges are needed and I am sure dj agrees with me. Ohm loads of motors are not matched which means if you just try to parallel the connections from 6 motors to one dual h bridged there is no way to predict how much power will go to each motor. Current draw can be uneven and motors may not turn at the same speed either. If motors are parallel wired to one controller you also have zero control between motors for torque steer adjustments. There's a list of reasons why not to do it but what you need to know is to just buy 3 L298n controllers and if you want to use one Movement Panel just splice your 5v power , ground and pwm signal from ez board to control all the right side motors and the other bridge connections applied in parrallel for the left side drive motors. 3 l298n motors are just 45 dollars in the EZ Robot store.
-oops i realized right after this it was 4wd
Lead acid batteries are the bomb. They are easy to use for beginners and cheap. 12v like the guys said is great.
@small correction- 4wd chassis only needs two L298n controllers. One for each axle. Dj is updating the store description since this was brought up. - Josh S
@Josh Good catch on the type of Thumper... I was basing my three multi motor controller aspect on the 6WD blush
@mcbaker01_and_everyone I still believe that with a sufficiently sized controller (admittedly not the L298n), you could run the motors parallel (per side)... as long as they are of same model/type... subtle differences should not matter. In fact, if there is such clear differences in current and resistance between motors, then even with separate controllers for each pair the individual motors on one side could rotate at different speeds or with differing torque, causing all sorts of other issues... unless you also have discreet control of each H-Bridge to compensate... which then eliminates use of the simple moment panel (only one per ARC instance) and complicates the controlling altogether for a new user.
Of course, in the end each robotisist will determine their own way based on advice, ingenuity and experience:D Don't take just my advice (or anyone's) take them all and experiment, at least that's how I learn.
@ Gunner, Excellent advice on last line!
