I want to set up a Battery Voltage Monitor script using the values from the EZ-B v4 Info control. Is this possible? If so, could someone please, give me some pointers to get a script started.
Thanks
NMS Navigation Data Grabber
— Query NMS lidar scan data by angle, with control commands for range, arc extremes, and obstacle checks from the latest scan.
Thanks
Can you be more specific? There is a control called EZB info that you can add to monitor the battery.
Ya, sorry. I should have explained what I want to do. I have the EZB Info control running. I am looking to create a script that would monitor the voltage and when it gets to a certain voltage, it would do something. ie, warning the voltage is low or shut down scripts that are running, etc.
There is a script command GetVoltage() that does exactly that.
You can use an if statement in a slow looping script...
You can use this as a base. Remove the ADC stuff and the extra circuit etc. since it's all now within ARC/the EZ-B.
What you are left with are the IF and ElseIfs for different battery levels. Loop it with whichever method you prefer.
@Richard R, that was exactly what I was looking for, thanks. Thanks to everyone else for your input.
