Task Script icon Task Script — Split complex robot tasks into sequential scripts, synchronizing asynchronous skills via NEXT/CANCEL commands for staged automation. Try it →
Battery Not Charging
Hello,
I keep getting the battery is low message and when I try to charge it, it takes about 20 seconds to charge and I get a green light on the charger saying its ready. As I Turn it back on it starts with the "my battery is low again. I should also mention that the ez robot is right out of the box brand new. Double checked the Battery Care & Charging Video https://synthiam.com/Community/Tutorials/26, and Read the FAQ https://www.ez-robot.com/Tutorials/FAQ.aspx and I haven't found a solution.
It should also be noted that we are using LiPo Battery Balancer Charger which only has 2 LEDs and not three. Maybe I'm looking in the wrong place.
Checking the ARC windows app and looking for the bettery voltage, I might be reading it wrong but is says "EZ-B voltage is 0.432592608". Which I assume means its toast. Any ideas?
Thanks
Thanks, the battery is not puffy, looks normal... I notice the pin board is a little loose, could this be a possible reason?
if the batt looks normal the only way i see is if the batt is to low on voltage. they will not charge anymore.
#11   — Edited
Thanks, it does say "my battery is low", but never seems to get a charge.
#12   — Edited
What’s the voltage of the battery? Easiest way to tell is connect to the EZ-B v4 and add the ezb info control: https://synthiam.com/Software/Manual/EZ-B-v4-Info-16059 i think you mean the ezb when you type "pin board". That’s the brain of the robot - super important part. If the pins aren’t bent it will cause a short. A pin would only get bent with misuse. Keep an eye on that:) robot abuse is a thing! Okay, maybe not but keep an eye on it anyway haha
CPU Temperature: 33.03 Celcius Input Voltage: read around 3 I believe...
Roli will only power on for about 5 seconds before dieing:(
I will keep an eye on the pins... my little guys are pretty responsible, but some of them are only 8...
Am taking them to an event called "Expo of Awesome" tomorrow - still the only school in our district to have these guys.
Looks like you’ll need a new battery:)
