Floor Map icon Floor Map — Draws a live floor map of robot movement using Movement Panel, logging direction, distance and heading; configurable speed and turn settings. Try it →
Battery Not Charging
Purchased JD for son for Christmas. Battery will not charge. Lights flash 6x indicating 300mv difference of voltage. Followed instructions on website to disconnect from robot and try again. Still not charging. Connected to website and checked the battery as per web instructions. Info reads CPU temperature 24.37c Input vol 5.42. What do we do? Is there anyway to contact a rep for the company? Not comfortable about there being no direct link to them. We have not had robot on for more that 5-10 minutes.
#17
Email me your address (my email is in my profile). I have a spare continuous rotation servo. I'll replace it next time I place an EZ-B order so the shipping won't be as much as the part.
#18
@thetechguru Did you mean you would be sending a continuous rotation servo out to them right away, or whenever you do another order?
#21
if the battery is not charging it must be because you overcharged your ez robot never charge him over night this will break your ez robot and you can never charge him again I did this and my new jd broke I had to return it and buy a new one you only have to charge your ez robot until the battery lights turn green hope it helps:)
#22
Nope not the case for me... Six came out of the box not charging. I know it is the battery because our adventure bot has never had this issue. Its charger did the same thing when used. Wondering if there are some bad batteries in the batch. The warnings are in red like DJ said. We read all the instructions and did everything right and tried to charge our battery first so it would be good to go. No such luck red blinking lights when we plugged it in. Now we wait.:( Good tip on finding one at hobby store may do that while we wait for response about our battery.
the charger stops automatic with charging when the the batt is full. its a two cell batt so two red leds chould go on.
