Display Popup icon Display Popup — Full-screen popup display for ARC: show custom text with configurable timeout, font, text/background color, size and position via controlCommand(). Try it →
THANKS STEVE AND RICHARD FOR YOUR HELP. STEVE CAN YOU SHOW ME A DRAWING ON HOW YOU PUT THE PARTS TOGETHER TO MAKE THE PLUG? I HAVE TO SEE IF I CAN FIND THE PARTS. I ALL READY TRIED RADIO SHACK.THEY HAD NOTHING!I WILL HAVE TO SEE IF I CAN GET SOME ONE TO DRIVE ME TO A NERE BY HOBBY SHOP. PS CAN I GET THESE PARTS AT THE ROBOT SHOP ON LINE? IF SO WHAT DO I ASK FOR?.THANKS AGAIN RGJUBILEE.
@rgjubilee - here are the product numbers from Robot Shop (at least from the Canadian site should be the sameon US).
When I made my adapter, I used the end off of the switch unit in the picture below.
When you wire up the Deans to Barrel, you will go positive to center and ground to outer on the barrel.
If you use a barrel plug with wires and you are not sure about which runs to the inner and outer, use a multimeter to check continuity between the barrel and wire ends.
STEVE THANK YOU SO MUSH FOR ALL YOUR HELP. I'AM GOING TO ODER THOSE PARTS AND DO WHAT YOU SAID. IF I RUN IN TO A PROBLEM I WILL GET BACK TO YOU. YOU BEEN A GRATE HELP THANKS RG JUBILEE.
I DID NOT SEE MY VIDEO ON THE SITE SO HERE IT IS AGAIN I ORANGERY UP LOUD IT ON DEC 30.FOR THE CONTEST.STEVE THIS IS SOME OF MY ORANGE ROBOT DOLLS OF MY CARTOON CARTERS FROM MY 3D ANIMATED MOVIE [QUEST FOR THE KING JOINERY IN TO PARADISE]YOU CAN SEE IT ON YOU TUBE IT IS IN 9 PARTS THE FULL MOVIE RUNS 4 AND A HAFT HRS. YOU CAN ALSO SEE IT ON MY FACE BOOK AS WELL AS SEEING MY BUD OF THE [QUEST ALIVE DOLLS.
AGAIN I'AM TRYING TO LOUD UP THIS VIDEO!~! I MAY KNOW HOW TO MAKE MOVIES AND GET THEM ON [YOU TUBE] AND MAKE ROBOTS/ BUT GETTING THEM ON THE E-MAIL ? THAT'S ANTHER STORY!?LOL!
Are you trying to post a video here on the forum? You have to upload it to YouTube, then link it here...
#15
YES BUT HOW? I TRUED EVERYTHING[ WART IS A URL?
#16
A URL is a web link (stands for Uniform Resource Locator)... www.ez-robot.com is a URL... www.eBay.com is a URL... You have already done this in your first post, so you must know how?... So do it the same way as you did in your first post...
