What Mini Itx is most compatible with the EZ-Board? Any advice on how to use it with the EZ-B would be helpful.
Amount of RAM, HD space, etc.?
Continuous Servo
— Control a 3-wire continuous 360-degree servo in ARC: adjustable forward/reverse speeds, start/stop buttons, board/port selection and test controls
I like MSI brand mother boards.
Josh has a really nice set up on his Omnibot/vacuum project Jarvis. You could check out his thread for more info.
working my way through it now......also looking for advice on getting it up and running with EZ-B.
Asus C60 M1 AMD Fusion Dual core cpu 79.99 mini itx @ newegg.com
Excellent fanless pc. Give yourself 4gb ram and whatever hd you like. Solid state boots really fast. Use a Bluetooth sub adapter to wirelessly interface with ezb.
Pico power supply 90 watts or above will power your board from a 12v sla battery for hours.
https://www.newegg.com/Product/Product.aspx?Item=N82E16813131843You can pick whatever hard drive you want. This board used sata and u prefer western digital or Samsung for quality reasons.
https://www.newegg.com/Product/Product.aspx?Item=N82E16822136771
This is the hard drive I have. 59.99 250gb
Please be sure to install windows 64 bit so that you fully utilize the second cpu core and full memory bandwidth.
Have you looked at the Nano-itx or Pico-itx boards?
