I have a script that I want to run none stop. What is the best way to do this?
— Edited
4 Participants
Output Audio From EZ-B
— Example ARC skill demonstrating converting, compressing and streaming MP3/WAV to an EZ-B speaker, with play/stop commands and TTS examples.
Adjust the sleep as required but it's always an idea to have a slight delay to avoid resource hogging.
I prefer using the repeatuntil command for continuously running loops....
Rich, I thought the goto would only work in an IF statement.
Richard R, I'm having trouble working with repeatuntil.
Labels and Gotos work anywhere.
Basic loop
I would recommend using Goto instead of RepeatUntil(0) because the Goto will use 1 less cpu instruction than RepeatUntil(0). That means a goto is a teeny bit faster
Thanks guys. I'm slowly learning this. Its hard to learn easy things when all the Arduino and other things I'm use to using are much more comp0licated. I seem to be overthinking things a bit.
Thanks for all the help.
@DJ, that's good to know. For some reason I thought the repeatuntil would be way faster and more efficient than the old goto loop. Sounds like they are not much different in terms of resources. Maybe the repeatuntil is just a little more neater to look at. I guess it depends on who you are.
