UBTECH Alpha Servos UBT-12HC icon UBTECH Alpha Servos UBT-12HC — Control UBTECH Alpha UBT-12HC smart servos via ARC using EZ-B v4/IoTiny UART, assign virtual ports, set baud, custom bits and position mapping. Try it →
kamaroman68
ok thanks
hi thanks
now just a pic connection roli to motor board.
Open ARC, Goto File, Open, Examples, Open Roli. It should ask you if you want to open the Assembly Instructions. Click Yes. It will walk you thru it.
rz90208
offcourse i forgot about that.
thanks
