Tic Tac Toe icon Tic Tac Toe — Play Tic Tac Toe with your ARC robot: configurable turn, win and draw scripts, cheat commands and optional speech-recognition control. Try it →
Bigtrak As A Rover Platform
What I think would make a great rover platform for the EZ-B is the retro Bigtrak that came back in 2010. This was based on the 1980 hugely successful toy that sold in millions. You can pick them up on Ebay for as little as 10.
https://www.ebay.co.uk/sch/i.html?_trksid=p5197.m570.l1313.TR1.TRC0&_nkw=bigtrak&_sacat=0&_from=R40
What is cool about Bigtrak is that it has a magnetic clutch that lets the rover move in straight lines, this is a very clever design and was in the original toy in the Eighties. Also it is possible to "tap into" the existing H bridge on the main PCB, which you can see from the picture below. The motors also have encoders this is how Bigtrak knows where and how far it has moved when sent on a mission.
So for around 10 quid you get a great rover platform that has encoders on the drive motors with a magnetic clutch together with 2 H bridges that are accessible if you remove the original microcontroller hybrid board.
My toy invention company (Conceptioneering) has designed and licensed the next generation of Bigtrak which we have called Bigtrak XTR (Xtra Technology Robotic) here is the original sizzle that we did for it
At the end it is chasing the ball by itself using colour tracking, Bigtrak XTR is set to be on sale this Christmas.
Spain
Toymaker that's a very cool platform, missed her here. I guess the magnetic clutch corrects the small difference in speed of the motors to go in a straight line as mentioned, if so they had had a great idea 30 years ago. I'm sure the XTR Bigtrak new platform will be a very salable product, greetings.
Hi R2
Yes the magnetic clutch works by having magnets on both sides to the dual motor gearbox, when moving forward there is just enough attraction to let the magnetic clutch lock and the Bigtrak usually goes in exactly a straight line. When turning left or right in a skid/steer system like this, the magnets are forced to disengage by the turning and unlock temporarily.
I have some units here, and if you start them from a known point they usually get to where they have been programmed to go previously. Thick carpets can cause traction errors, but on a solid floor its quite amazing how accurate their movement can be.
I've been on the look out for one since you told me about it. It's just what I need for a test bot upgrade.
Also, the rocket launcher and drinks can carrier can still be found all over the place, do you know if the rocket launcher is easy to add to the EZ-B? Camera + rockets = loads of fun!..
I agree with Rich it could be great test platform. But I really dont another noisy clattering Robot so is it quieter than say an 80's Omnibot? does anyone know?
I use to have one as a kid!
This brings back memories! I'm kicking myself because I had one of the originals up until about 2 years ago. I gave to a friend of mine, because he found one of the trailers. If I remember correctly, they were not extremely noisy, but definitely not silent.
Rich, the rocket launcher is on the accessory port and pretty easy to control from an EZ-B
On noise have a look at one of the distributors video of our XTR, the retro Bigtrak is about the same noise, also on this video you will see the rocket launcher working.
I also had one years ago, but they were expensive then, I think they retailed at $40 which in 1980 was a lot of money.
