Servo Script icon Servo Script — Bind scripts to servo moves (V1-V99); triggers on position/speed/accel changes and provides ports, positions and speeds arrays for custom control. Try it →
Resolved Resolved by Athena!
Bing Speech Recognition Wake-Word Pause Issue
I have a question about the ARC robot skill "Bing Speech Recognition".
I am using the Bing Speech Recognition skill with wake-word enabled. The wake word works correctly and the skill plays the wake-word ding. After that, it starts listening and normally sends the recognized phrase to my script via the $BingSpeech variable.
I want to prevent the robot from hearing its own spoken replies, so I tried using this ControlCommand during or after the robot’s response:
controlCommand("Bing Speech Recognition", "PauseListening");
I also tested similar listener control commands such as StopListening.
After PauseListening or StopListening is called from a script, the Bing Speech Recognition skill no longer works correctly with the wake word. The wake word still appears to trigger (the ding plays), but the skill gets stuck at "sending data" and never completes recognition or runs the recognized-speech script.
Manual operation still works. If I manually press Start Recording, speak a phrase, and then press Stop Recording, recognition works and my script runs correctly. The issue only appears after using the listener control commands from a script.
For troubleshooting, I replaced my recognized-speech script with a simple print of $BingSpeech, and that works correctly. I also removed the PauseListening / StopListening control commands from my script, and wake-word recognition works again.
So it appears that calling PauseListening or StopListening from a script may leave the Bing Speech Recognition wake-word flow in a bad state.
My question: Is PauseListening intended to be safe to call from a script while using wake-word mode? If so, is there a recommended way to pause Bing Speech Recognition during the robot’s speech and then safely resume it afterward?
Environment:
  • ARC on Windows (PC-connected)
  • Robot Skill: Bing Speech Recognition
  • Wake-word enabled
  • Recognized text variable: $BingSpeech
  • Script invoked from the Bing Speech Recognition recognized-speech script
Offline Windows speech recognition with open dictionary, confidence filtering, and scriptable phrase actions for ARC robots
#9   — Edited
A fix has been added to the next release of ARC, which will prevent the "sending data" hang. A fix has also been added to the pause unpause for using the Say commands toward any speech recognition robot skills.
