EZB Connection icon EZB Connection — Connects EZ-B I/O controllers to ARC via COM or IP (5 connections). Supports init scripts, battery monitoring, TCP/EZ-Script server and serial/I2C. Try it →
reboot and reinstall the plugin?
OK Will do.
I'm loving computer vision, i laughed so hard.....read 10% chance...
@fxrtst I just tried cognitive vision too.... @DJ This works fantastic... Thanks for this plugin!:)
OK rebooted and reinstalled, get the above message and this now:
Anyone else getting same issue?
@richard do you have the speech plug installed? Did you have an issue?
  1. Tell me step by step how you are installing the plugin.
  2. How many copies of ARC do you have loaded at once?
  3. What web browser are you using?
Deleted the folder and reinstalled plug, to make sure the speechclient.dll was in the folder. It is, but its not finding it in the plug folder on start up.
  1. No ARC active. Downloaded plug in. Double clicked to install. Says plug was installed sucessfully. Start ARC. Open test file you uploaded. Get error.
  2. One copy.
  3. Chrome to download files.
