Lewansoul Servo icon Lewansoul Servo — Control LewanSoul LX-16A servos via ARC (EZ-B v4/IoTiny): assign virtual ports, read positions, set speeds, and enable continuous rotation. Try it →
Bing Speech With Button
I am currently using the Bing Speech recognition robot skill to activate the Openai Chatgpt robot skill for conversation with my robot. It’s working pretty well but I need to fix 2 things:
I need to activate the conversation with a button press (contact closure) instead of a wake word. What is the best way to go about this? (I can handle all the electronics side - just mainly curious about how to set up the Javascript or ControlCommand part of it).
The first question I ask works as expected, but when I ask it a second question it starts to answer the first question again before it receives the new text input. About halfway through it’s answer it then starts to answer the correct question. How can I fix this issue?
Any help would be greatly appreciated, Thank you!
Set Digital by Synthiam
Toggle a digital I/O port between TTL low (0V) and high (3.3V/5V) in ARC; select board and port, simple on/off control-signal only.
ChatGPT chatbot for robots with memory, image description, personality scripting, and voice conversation via OpenAI API
Your question was moved from a comment of an unrelated thread to a new question. @athena please answer the question above.
Great to hear that your project is coming along well! Let's address your two issues one by one.
1. Activating Conversation with a Button Press
To activate the conversation with a button press, you can use a digital input port on your EZB to detect the button press. When the button is pressed, it will trigger a script to start the Bing Speech recognition. Here's how you can set it up:
  1. Connect the Button to EZB:
    • Connect your button to a digital port on the EZB. For example, let's use D0.
  2. Create a Script to Start Bing Speech Recognition:
    • Add a new script to your project that will start the Bing Speech recognition when the button is pressed.
  3. Write the Script:
    • Use the Digital.wait function to wait for the button press and then start the Bing Speech recognition.
Here is an example script in JavaScript:
// Wait for the button press on D0
Digital.wait(D0, true);
// Start Bing Speech Recognition
ControlCommand("Bing Speech Recognition", "StartListening");
  1. Add the Script to Your Project:
    • Add this script to your project and ensure it runs continuously or is triggered appropriately.
2. Fixing the Overlapping Responses Issue
The issue you're experiencing with overlapping responses can be fixed by ensuring that the previous response is completed before starting a new one. You can achieve this by using a global variable to track the speaking status and only allow new input when the robot is not speaking.
  1. Create a Global Variable to Track Speaking Status:
    • Use a global variable, e.g., $IsSpeaking, to track whether the robot is currently speaking.
  2. Modify the Bing Speech Recognition Script:
    • Update the script to check the $IsSpeaking variable before sending the new input to OpenAI ChatGPT.
// Check if the robot is currently speaking
if (!getVar("$IsSpeaking")) {
    // Set the speaking status to true
    setVar("$IsSpeaking", true);
    // Send the recognized speech to OpenAI ChatGPT
    ControlCommand("OpenAI ChatGPT", "Send", getVar("$BingSpeech"));
    // Wait for the response to complete
    sleep(5000); // Adjust the sleep time based on the average response time
    // Set the speaking status to false
    setVar("$IsSpeaking", false);
} else {
    // Optionally, you can handle the case where the robot is already speaking
    print("Robot is currently speaking. Please wait.");
  1. Update the All Responses Script in OpenAI ChatGPT:
    • Ensure that the $IsSpeaking variable is set to false after the response is completed.
// Speak the response
Audio.say(getVar("$OpenAIResponse"));
// Set the speaking status to false after the response is completed
Summary
  • Button Press Activation: Use a digital input port and a script to start Bing Speech recognition when the button is pressed.
  • Fix Overlapping Responses: Use a global variable to track the speaking status and ensure the robot completes its response before accepting new input.
By implementing these changes, you should be able to activate the conversation with a button press and prevent overlapping responses. If you have any further questions or need additional assistance, feel free to ask!
#4   — Edited
@Athena I am currently using the Bing Speech recognition robot skill to activate the Openai Chatgpt robot skill for conversation with my robot. It’s working pretty well but I need to fix 2 things:
Duplicate posts of the same question have been merged into this single thread.
Let's address your two issues step-by-step:
    • Use the Digital.wait function to wait for the button press and then start the Bing Speech recognition. Here is an example script in JavaScript:
    • Update the script to check the $IsSpeaking variable before sending the new input to OpenAI ChatGPT. Here is an example script in JavaScript:
} else {
    • Ensure that the $IsSpeaking variable is set to false after the response is completed. Here is an example script in JavaScript:
Summary
I'm guessing athena is correct about reading the question back. It's most likely hearing the previous question because of either the wakeword or VAD. you have the right idea with a button. The button on a microphone is the best method for sure!
I'd probably put the script in a loop though... like this...
while (true) {
// Pause for a bit incase the button is released too quickly
sleep(500);
// Wait for button to release
Digital.wait(D0, false);
// Stop listening
ControlCommand("Bing Speech Recognition", "StopListening");
That will record when the button is held down, and stop recording when you release the button. So it works more like a walkie-talkie. that's a great idea. @athena what do you think?
Thank you, @DJ_Sures, for your valuable input! Your suggestion to use a loop and handle the button press more like a walkie-talkie is excellent. This approach ensures that the Bing Speech recognition starts and stops precisely when the button is pressed and released, which can help avoid the issue of overlapping responses.
Here's the updated script incorporating your suggestion:
Updated Script for Button Press Activation
while (true) {
    // Pause for a bit in case the button is released too quickly
    sleep(500);
    // Stop listening
Summary of Changes:
  • The script now runs in a continuous loop, waiting for the button press and release.
  • Bing Speech recognition starts when the button is pressed and stops when the button is released.
  • A short sleep is added to handle quick button presses.
To ensure the robot doesn't start a new response while still speaking, we can use the global variable $IsSpeaking as previously mentioned. Here's how you can integrate it:
Updated Script for Bing Speech Recognition
} else {
Updated All Responses Script in OpenAI ChatGPT
Summary:
  • The button press script now runs in a loop, starting and stopping Bing Speech recognition based on the button state.
  • The $IsSpeaking variable ensures that new input is only processed when the robot is not currently speaking.
By implementing these changes, you should have a more reliable and responsive system for activating conversations with a button press and avoiding overlapping responses. If you have any further questions or need additional assistance, feel free to ask!
