EZB Connect By Name icon EZB Connect By Name — Discover EZB WiFi controllers by name, auto-bind connections, avoid IP management; live discovery and multi-EZB support for ARC. Try it →
#17
I2CWrite(0,0x09, c, 0xff) Sleep(5000) I2CWrite(0,0x09, c, 0xc4)
What happens is I have to move the sliders to change the color, then execute script, the first line is ignored then it changes to the second color. Its almost as if the Blink M control panel is over riding with the first color and the script picks up the second color.
#18
Have you tried it without the blinkm control panel being loaded in to the project?
#19
Just did. No luck. Once killed it stays at the last color I chose and again skips the first color but changes to the second.
#20
@DJ how about an Auto Position option for Blink M's so animations are possible? If i can use sliders those sliders should be able to be animated over time?
