Servo Pad icon Servo Pad — Drag mouse or finger as a virtual joystick to control pan/tilt x- and y-axis servos with configurable ports, limits, inversion, and backgrounds. Try it →
The BlinkM is an I2C device so therefore you connect it to the I2C port.
If you have a V3 EZ-B it will plug directly in to the I2C port if you want to or you can run wires to it if it's away from the board.
If it's a V4 you can connect to any of the three I2C ports.
it works!:)
