I'd replace the known bad parts on the ezb before you test it.
Went with Daves advice to be on the safe side and everything worked out
Outstanding. I damaged my old V3 EZB a few years ago a couple times doing careless things in a hurry. They'er easy to fix (as long as you don't blow the main chip (that's hard to come by).
I replace known bad parts on electronics's. Then I do some testing with a multi meter looking for proper values (if I know them) and test for continuity to ground that shouldn't be there (a short). Then I hold my breath and fire it up and hope I really dont fire it up (if you know what I mean). ;)
