Dual Hbridge W/PWM icon Dual Hbridge W/PWM — Dual H-Bridge w/PWM movement panel: control two DC motors' direction and speed via EZ-B PWM for responsive forward/reverse/turning. Try it →
Probably low power issue try fresh batteries or a lead acid 6v battery.
Hi I'm using the bench top power supply. I got it along with several other items with my order. So a power problem is probably not it.
That sucks , I will tell you it doesn't pair to all Bluetooth , are u using win 7 with latest updates?
Hi Yes I have tried it on Win 7 32bit, Win 7 64bit and XP 32bit
Are you using the same Bluetooth adapter trying it on different computers? Is it a usb blutooth adapter?
