Indoor Positioning System icon Indoor Positioning System — Infrared indoor positioning for ARC robots: dual-camera tracks IR beacon, shows real-time heading, path and EZ-Script navigation variables Try it →
Bluetooth Connection Question
Hello from Russia. I'm trying to connect with my ez-robot. Step 5 from the video tutorial is going fine. But when I'm trying to connect to my ez-robot (the lowest port is COM8) form the ARC I'm getting error:
EZB 0: EZB 1: EZB 2: EZB 3: EZB 4: TCP Server stopped TCP Server stopped TCP Server stopped TCP Server stopped TCP Server stopped Attempting connection on COM8 Comm Err: ????? ???????? ???????? ???????. !(it says about time out) BbytesToExpect: 1
Received: Disconnected Connection Failed: System.Exception: Controller Not Responding ? EZ_B.EZB.Connect(String hostname, String tcpPassword, Int32 baudRate) Disconnected
Does anybody know what is going on? Thanks in advance.
Yes, I can verify. The red flight flashes and the blue light light pulses.
I'm sorry, when I say the lowest, I'm talking about the lowest number, not the lowest position on the screen.
Anyway, I've tried to connect to COM3 as well as to COM5
EZB 0: EZB 1: EZB 2: EZB 3: EZB 4: TCP Server stopped TCP Server stopped TCP Server stopped TCP Server stopped TCP Server stopped Attempting connection on COM3 Comm Err: ????? ???????? ???????? ???????. (time out) BbytesToExpect: 1
Received: Disconnected Connection Failed: System.Exception: Controller Not Responding ? EZ_B.EZB.Connect(String hostname, String tcpPassword, Int32 baudRate) Disconnected Attempting connection on COM5 Connection Failed: System.TimeoutException: ????? ???????? ???????? ?????? ???????. (time out) ? System.IO.Ports.SerialStream.Write(Byte[] array, Int32 offset, Int32 count, Int32 timeout) ? System.IO.Ports.SerialPort.Write(Byte[] buffer, Int32 offset, Int32 count) ? EZ_B.EZB.Connect(String hostname, String tcpPassword, Int32 baudRate) Disconnected
That tripped me up too, is it the lowest port number or the lowest on the screen ?
It's the lowest port of the two which are added when the EZ-B is paired with the PC.
Click Start --> Devices and Printers
Right click on the EZ-B --> Properties --> Services
Both of mine only show the one COM port which is the one to connect to. If it shows 2 it's the lower of the 2 (i.e. if it shows COM10 and COM11 choose COM10)
Chernyshov
Check if you are using the Microsoft standard bluetooth drivers You have an odd looking bluetooth device in your system tray. I would delete all Bluetooth devices and Drivers and start again with just the EZ-B. It looks like you have a bluetooth dongle device plugged in does your laptop not have BT built in? unusual nowadays it maybe a conflict
Its unlikely to be a language issue as others have been succesful in Russia
Just remember that if your computer/laptop device has bluetooth built-in it will be a class two device that may be capable of up to 10 meters, (33 feet) of communication distance.
#15
We have tried to connect from three different laptops. Unfortunately, still getting the same error. I'd like ask you, maybe any of you could connect to my laptop remotely and try to help. It was supposed to be a present for my son, who actually has found ez-robot web-site. He really wants ez-robot work.
my ez-b is doing the same thing now it was working fine, then when i tried to connect this came up.
Attempting connection on COM3 Comm Err: The operation has timed out. BbytesToExpect: 1
Received: Disconnected Connection Failed: System.Exception: Controller Not Responding at EZ_B.EZB.Connect(String hostname, String tcpPassword, Int32 baudRate) Disconnected
