Bluetooth Requires Reset On Power Cycling Ez-B
I can connect to the EZ-B no problem, but I have to reseat my bluetooth adapter every time I power cycle the EZ-B. Any ideas? The wall-e I built has located the EZB in a very remote location. I am contemplating rerouting the 4 connection wires to the outside of the robot case so I can do this remotely, but that is a bit hack.. Are there any easy solutions for this? I am finishing the xmas present for tonight lol (its a bit tight on time)..
Thanks and Merry Xmas !
If the bluetooth adapter does not power up with the EZ-B, then your batteries are low. I experience that issue often also. I feel the real solution for us is to start using a 6 cell AA battery pack - instead of 5 AA.
Servos are power hungry!
