SSC-32 Servo Controller icon SSC-32 Servo Controller — ARC integration for SSC-32 servo controllers via PC COM or EZ-B/Arduino UART; maps V0-V31, configurable baud, enables servos in ARC skills. Try it →
Boogie Question
I got my camera today ( the little blue one just like DJ's) and installed with the software that came with. When I select USB video device I get the. Built-in web cam. Will I have to disable the integrated web cam? Sorry bout that.............. I meat " noobie" question! I just hate ". Autocorrect!!!!!! The salutation for this post was meant to say: A noobie question!
Hahaha, I like boogie question.
You have a drop down with all of your cameras. well, you should. If you plug the camera in after you load the control then you will need to press the REFRESH button. Otherwise, all of your cameras will load into the drop down. Select which camera you'd like to use.
