it has android 4.0 system will it work with EZB and how got it from newegg for $549 1.40 ghz WIFI,and bluetooth
robotmaker
— Edited
5 Participants
Custom Movement Panel V2
— Custom Movement V2 panel for ARC: scripts for F/R/L, Reverse, roll left/right, up/down with speed mapping to PWM for drones, mecanum & custom drives
Eventually - we are trying to hire a mobile developer to finish the app
In the meantime, look at mobimotion (i think there is an android version) - it connects to ARC nicely
i can cancel it since not shipped yet would i the new IPAD be better to use,i also have a IPOD 3RD GEN
When the app is released, it'll work for both devices
Robotmaker , are you looking at android phones or tablets?
The app sounds fun - real fun. My wife is hunting down a quality netbook with windows OS on E-bay. I'll post the details the minute we find it. Cheers
tablets only,not much into phones,netbooks are great for robots,have 2 on robot designs
Hi Robotmaker...
The problem with tablets, from what I've seen is most run off android (ideally we want Windows 7). I've been looking at netbooks and most of the 7inch ones use windows ce (not the best for what we want to be able to do with our robots). So, we are now looking at 10 inch netbooks and many of them run windows 7 and are reasonably priced $200-$300. We just adjusted Bobs width to accommodate the 10 inches needed.
not using it in my robots only to control and keep a eye on them second netbooks dont fit inside most robots ,best to use is a ITX board scond WINDOWS 7 you need more power to run 64 bits or if running 32 bits i found is much much slower because of all the add-ons using a benchdrive test,that if you look at every robot made ,new or older all use WINDOWS XP PRO or LINUS,NONE ON THE MARKET USES WINDOWS 7 most like it beacuse it the lastest software and has a lot of bells and whistles what happens when windows 8 then windows 9 and then windows 10 come out
