Connect the esc to any digital port. Add a servo control. It will work the same as a regular servo. Usually esc's need some "configuration" when first powered up. You will need to read the manual for it. The configuration is usually move to highest position, move to lowest position, move to center position. Some esc's will beep when each position is determined.
