Kondo KRS ICS Servos icon Kondo KRS ICS Servos — Control Kondo KRS ICS2/3.5 servos via EZ-B UART; experimental, untested. Supports chaining, virtual servo ports, Release() and Servo() commands. Try it →
Bug Report: Ez-b In Client Mode Still Running Dhcp
Bug Report: Ez-B In Client Mode Still Running Dhcp
EDIT EDIT EDIT: See post 16 for explanation of the cause, and a possible solution
I have mentioned this in a few conversations about network issues, but I don't know if DJ saw it since the issues were marked a resolved before he commented, so I am opening an explicit thread for this bug report.
While troubleshooting some strange issues on my 802.11g and n network when running multiple EZ-B's (specifically, EZ-B's and the few other G or N devices I have refusing their reserved IP addresses and getting other addresses, not showing up in the DHCP client list of my router, and some strange error messages in the router log) I ran wireshark on a computer connected to my 802.11n network with a display filter looking at bootp messages then powering on EZ-B's.
The first EZ-B come up normally and connects to my network with normal messaging.
When I power up the second one, and it sends out a discover, both my router, and the first EZ-B send out an offer. The EZ-B accepts one of the offers (usually the one from the first EZ-B), and rejects the other (and the router sends out a reject and logs an error because it is seeing another DHCP server on the network).
When I power up a 3rd EZ-B, the first 2 send offers.
4th EZ-B, the first 3 send offers.
Any other device also get DHCP offers from the EZ-B's as well as the router.
Thankfully most of my network is on 802.11ac or wired and not impacted by this, but the few 802.11n devices behave very strangely when the EZ-Bs are on (losing their internet connection, or restarting their network connections).
Hopefully this will be an easy firmware fix, because it is actually fairly serious and unfortunately validates the few network administrators who have told users here that they can't put the EZ-Bs on their networks. Having more than one DHCP server on a network is a major networking policy violation.
DJ, Have you looked into this issue yet? It is still causing irritating issues if I don't start my EZ-B's in the same order every time, and I believe it is causing the issue I am helping @oldbotbuilder troubleshoot where his wife's PC disconnects from the network whenever he connects his EZ-B to his router.
I've contacted the manufacturer of the tcp stack that is licensed for our wifi modules - we're at the mercy of their response.
Thanks DJ.
I am hoping this will be a simple firmware update.
It won't be - there is no way to update firmware on the wifi modules because they're static. Best we can get from them is an answer on a configuration setting or to acknowledge the issue.
As I suspected, the reason not everyone sees this is that some routers are faster at responding to DHCP requests and mask the issue.
I just got a new FiOS Quantum Gateway (Greenwave Systems) router for my Verizon FiOS service, and when I set up the robots to connect with it, they each get their assigned IP addresses regardless of which starts first, and other wireless devices get assignments from the router even when EZ-Bs are running. On the other hand, it is not a very configurable device compared to others I have tested. For instance, I can not specify the DNS provider I want my devices to use.
I experienced the issue on 3 different TP-Link routers and an ActionTech router (my older Fios Router), but the TP-Link at least are much more sophisticated devices, so I will just use the FiOS device for the robots on their own network, and continue using the TP-Link for the rest of my network bridged to the FiOS router to get internet access.
I don't know if this is effecting the issues I'm currently having, but was there any word from the manufacturer of the tcp stack, as it has been 4 months now?
#15
The manufacturer of the wifi chip used in the EZ-B v4 had communicated with additional detail about the DHCP. The DHCP on the wifi chip is delayed to "wait and see" if there is another dhcp server on the network. This is a feature used for portable networks where there is no dhcp and only a common access-point. Because this wifi chip is optimized for use in robotics, plc, iot and other portable network applications, it is common for these networks to not have dhcp servers. So the wifi IC delays and responds accordingly. Due to the slow processing speed of some older home routers, their dhcp server may respond slower and therefore trigger the dhcp server of the ez-b v4 wifi chip.
This is why ez-robot has been unable to reproduce the experience which alan had introduced in his thread - in both my home and office network. This instance has only arisen less than a handful of times on the forum, and has been resolved with router upgrades.
The DHCP delayed server does not affect communication performance. DHCP is the protocol used to issue IP addresses to devices and computers on a physical layered network. This means a network not separated by routers, such as your home network.
If the DHCP delayed server is responding due to the delayed response of the home network router, report your router model and version here to me with a description of the experience and i will compile a trouble ticket with the vendor for resolution.
Something to note, the wifi ic on the ez-b is being discontinued by the manufacturer, which may mean no further upgrades. Even though there will be plenty of surplus inventory of the wifi chip, ez-robot does not manufacture hardware with discontinued components - so ez-robot is changing the wifi chip for 2016. Due to the modular design of the ez-b v4, the communication board of the ez-b v4 can be swapped out with the new module when it is available - if the issue with delayed dhcp continues to cause issues.
If you want the DHCP completely disabled - and control over the wifi module code directly, you can re-flash the wifi module. All you need is one of these: https://www.ebay.ca/sch/i.html?_from=R40&_sacat=0&_sop=15&_nkw=pickit+3+clone&rt=nc&LH_BIN=1
If you purchase one of those PicKit 3 Clone Programmers, i can create a quick tutorial and provide the firmware source code which entirely disables DHCP on the chip. Alan, this applies to you or anyone as well. Unrelated to Alan's dhcp server experience, ez-robot has been thinking about releasing the webserver firmware open-source for customizing web UI and additional custom features. Perhaps this is a good time to do it. Get one of those pickit 3 clone programmers (the clone ones work great and are cheaper) and i'll get on pushing the wifi code on this website.
With the PicKit 3, the ez-b v4 wifi source code and webserver of the ez-b v4 can be modified for custom logo, html and branding. It'll be pretty awesome:D - I guess you can even change the TCP ports of the camera and ez-b protocol as well. Lots of power in that code release - including disabling dhcp entirely for station mode.
Lastly, if you believe the performance is far too unusable - there may be a defect in the manufacturing, which is unlikely but possible. That being said, feel free to Contact Us and send the ez-b v4 directly to our facility in Calgary, Alberta for review.
#16
I just ordered one of the programmers. I did not expedite the shipping, so expecting in a few weeks. I'll be happy to be your "beta tester" for the tutorial.
