Netherlands
Bug With Virtual Robot
i found this bug when i added 10x the same digital output port in the virtual robot screen (for each led on the place i wanted), then i tried to delete one, worked. but then i tried to delete another one, bam, a just in time error. description in the image: (dutch)
which basically says: index out of range.
luckily windows gave me the option to continue and the program still worked fine after hitting continue.:)
edit:
software version: 2013.1.12.00
