Autonomous AI icon Autonomous AI — Autonomous AI robot skill with vision, speech, movement, animations, and self-directed task execution powered by LLMs. Try it →
You can use any third party camera that works with Windows (which should work within ARC too), however you cannot use any other camera that plugs directly into the ezb4...
@handy03.
As Richard has stated, I'm not aware of any other camera that will work plugged in to the EZ-B except for the EZ Robot camera. But if you wanted to experiment, here are the EZ-B v4 camera port specs that tells you what the pins do.
You can experiment all you want but it wont work since the EZ-Robot Camera uses a custom codec.
hi thank you Richard and Steve G for the in put.;)
