Neopixel Blaster icon Neopixel Blaster — DIY NeoPixel Blaster for ARC - open-source controller for up to 8×80 LEDs (640), port‑0 onboard RGB, color control via ControlCommand Try it →
Camera Config Settings Save
Hi all,
I am not sure but it appears there may be a button missing on the new build. If you go into camera config and open the 'settings' window there is no save button and the settings don't save. The only way you can get out of the settings window is to 'X' out and your settings don't save. Is anyone else having this issue? I am pretty sure I remember a save button on the previous build.....or I could be losing my mind and am missing something obvious.
I am running 1211.12.26.00
v/r
Kevin
Oops, thanks:)
Upgrade to 2011.12.26.01 for fix:D
