Graphy icon Graphy — Plot live data with ControlCommand scripts: multi-series charts, many chart types, legend toggle, add/remove series, export graph data to CSV Try it →
I loaded the latest version of ARC and now the program runs slow. If I put the camera on pause everything is as usual however with the camera on, it takes between 2 and 4 seconds for the program to respond to any mouse click. I tried deleting the control and puting in a new one. No help.
There have been no changes to the camera control. Try rebooting your computer. Also load the Benchmark control from Utilities and see what the CPU value is.
You may be running a third party program in the background that is using your resources.
You can post your EZB file here and I can review it for you.
Buster13.EZB Here you go. It is kinda big. I also noticed that it is okay sometimes but not often. Thanks for any help.
DJ, I tried again tonight but it only got worse. Now the curser freezes for 5 to 10 seconds with or without the camera on. I checked as you suggested and can find nothing running in the background. Task Master performance is extremely low and showes nothing esle running. The system I am on is brand new and very little is on this computer. Can you please take a look at the file and see if I have done something to create this phenomenon. Many thanks!
That's real neat to see other peoples projects. Real cool:) I had fun looking through it. Lots of scripts!
Is the speed different when you are not using Auto as a tracking method?
I think so but will have to check on it tonight when I get home.
Hello, I checked it out and sure enough when on auto it slows down. When on view all seems to be running normaly.
