Dual-Axis Compass icon Dual-Axis Compass — Dual-axis I2C magnetic sensor for EZ-B robots enabling magnetic direction sensing; requires short 2-3 in wiring. Third-party hardware. Try it →
Portugal
Camera Control Error: System.Nullreferenceexception:
@DJ I get this repeating error message when I use object recognition and the smart variable watcher at the same time?
Camera: Camera Control Error: System.NullReferenceException: Object reference not set to an instance of an object.
   at System.Windows.Forms.Control.MarshaledInvoke(Control caller, Delegate method, Object[] args, Boolean synchronous)
   at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
   at System.Windows.Forms.Control.Invoke(Delegate method)
   at SmartVariableWatcher.FormMain.updateVariable(String var, Object val, Int32 index) in C:\My Documents\SVN\Developer - Controls\In Production\Smart Variable Watcher\MY_PROJECT_NAME\FormMain.cs:line 114
   at SmartVariableWatcher.FormMain.VariableManager_OnVariableChanged(String variableName, Object value, Int32 index) in C:\My Documents\SVN\Developer - Controls\In Production\Smart Variable Watcher\MY_PROJECT_NAME\FormMain.cs:line 49
   at ARC.Scripting.VariableManager.CreateVariableArray[T](String variableName, T[] values)
   at ARC.UCForms.FormCameraDevice.e1kjzfBldLE(List`1  )
   at ARC.UCForms.FormCameraDevice.hx2jzJhVodF()
Roomba by iRobot
Synthiam ARCx turns iRobot Roomba into a drivable robot with scripts, sensors, browser control, and AI-ready robotics skills.
Controller Dependant
Servos ✕
ADC ✕
Digital ✕
Efficient ARC Variable Watcher - lower CPU for large projects; slow initial array render but faster updates; shows name, type, value, length
The smart variable watcher is the error - not the camera. The smart variable watcher intercepts variable events. While it's useful for debugging, it can cause errors and performance problems when used. I can take a look but there's probably not much I can do. Probably the best idea is to have a smart variable watcher that allows you to select what variables to watch. That way it isn't showing the entire variable stack.
Portugal
It is not a major problem and it does not interfere as far as I can tell.  The interesting thing is that if I use the normal variable watcher I dont get any errors.
Yah I was gonna say the original watcher probably Won’t give this errors. It’s cause the smart one works differently. I’ll take a look and see anyway. I’m not a fan of errors
