EZ-B V3 Configuration icon EZ-B V3 Configuration — Manage EZ-B hardware settings: edit Bluetooth name and apply updates to restore altered configurations. Try it →
Camera Control Snapshot File Name
I have a script to command my robot to take a picture, after it takes the picture I have it open the folder location the picture went to so I can manually check the picture which works just fine.
#This opens the folder where the picture was saved
Exec("C:\Users\weyou_000\Pictures\My Robot Pictures")
What would be even cooler is if I could open directly the picture the robot just took, rather that just the folder. Does anyway know a way to do that? I am assuming I might need to catch the file name ARC uses when it saves the picture, but under the camera control settings and variables I did not see that as an option.
I've checked the ? and the setting gear of the camera control and I did not see an option for this. If it's not there could it be added in the future?
Thank you! -Justin
