PWM Servo Feedback (ADC) icon PWM Servo Feedback (ADC) — Add ADC positional feedback to hobby PWM servos via minor mod to EZ-B/Arduino; enables real-time position readout, calibration and puppet mirroring Try it →
Are you able to connect to your EZB? Which mode are you in, wp or client?
I can connect. I have the movement working. I have tried it in both WP and client. I'm currently using client.
Try unplugging and re-plugging the camera. If the connection isn't tight it can cause that error. Camera may have power, but not a good signal.
@Alan
Yeah I've defiantly tried unplugging it. I just pushed the clip down in case and tried connecting still says Camrea Disabled.
The full error out put is:
Quote:
12/3/2014 2:08 PM - Camera Initialized: EZB://192.168.1.12 @ 320x240 12/3/2014 2:08 PM - EZ-B v4 Camera Error: System.IO.IOException: Unable to read data from the transport connection: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at EZ_B.EZBv4Video.() 12/3/2014 2:08 PM - Camera Disabled
Does the blue light flicker? You may need to cup the camera in your hand to see the light flicker.
It flickers when it first turns on. After that nothing.
Hmmm, I had a camera that did that... turned out to be faulty so it was sent back to ez robot...
