ROS2 Connector icon ROS2 Connector — Bridge ARC to ROS2 via rosbridge: publish/subscribe topics for cameras, servos, ports, NMS, variables, scripts, and movement. Try it →
No.
If you wish to use OpenCV, then the EZ-SDK is for you.
There is an option in the camera settings for custom haar cascades which is compatible with OpenCV however, at this moment you can only use one.
Thanks Rich, I want to use some of the feature detectors in Opencv for tracking and object recognition.
