Bing Speech Recognition icon Bing Speech Recognition — Accurate Bing cloud speech-to-text for ARC: wake-word, programmable control, $BingSpeech output, Windows language support, headset compatible Try it →
There is a tutorial video on this site. I have done two cameras and before the mod they were very flaky. But, after the mod, they have been rock solid.
hope this helps.
Hey MovieMaker, do you knowwhich video?
You got it winstn60 - I followed what you did and it works beautifully.
I am a little late. sorry. I was going to say that both were fine. I did cut the battery off of it because it is so small and doesn't really do much. But, it works GREAT, doesn't it?;)
So can the camera safely handle to 5v connected tothe battery terminals? Or should you really step down the voltage?
A little late possibly but my camera has been running on +5v since I got my EZ-B and has had no problems handling it. Admittedly it's only been on for a short time and only a handfull of times. Soldered direct to the PCB as winstn60's method rather than cutting the USB cable.
It has an issue with the EZ-B turning it on and off - as in it turns on fine (sometimes without me even asking) but wont turn off. Not a problem as I don't ever want to turn it off when the ez-b is on. Is that normal?
