Roll Pitch Yaw icon Roll Pitch Yaw — Rotate and position camera or object with roll/pitch/yaw controls; save camera settings; bind or monitor a 3-value EZ-Script array for live rotation. Try it →
Camera Problem
Hello DJ, I installed the latest version of ARC and I am having a problem with my camera control. If I start a new file it works just fine but if I load my old file it is framed improperly and the color is all messed up and in addition if I try to config it errors out. I tried re-installing, use an older version of my program etc. to no avail. I tried deleating the old camera control and adding a new one but I get the same result.
This one really has me baffled. HELP!
I finally fixed it. I had to delete the control. Save the file. Re-open the file and add a new camera control. Problem solved.
