Display Popup icon Display Popup — Full-screen popup display for ARC: show custom text with configurable timeout, font, text/background color, size and position via controlCommand(). Try it →
Do you really need to ask? Just google Vista problems and you will find a list of literally hundreds of issues with Vista.
The fact Microsoft stopped support for Vista very quickly but continues XP support pretty much confirms that Microsoft know they screwed a lot up with Vista.
It's probably shorter to list what's right with Vista.
I ran vista just fine. However I have bug machines. Ialso killed all the UAC stuff.
I am on windows 7 now on all machines except 3 which are on windows 8
I agree 7 is much more usuable.
One good thing you can about Vista is that it isn't "ME";)
You know, I think ME was better than Vista... but it's like saying that the flu is better than malaria.
"As your project gets more complex you may find some slowdown with only 2Gb RAM, it may pay to either upgrade that to 4Gb or downgrade W7 Ultimate to W7 Starter (or remove services and applications etc. that bog it down)."
So what your saying is , " I have a PC that is like boiling an egg with an Atomic Reactor but to run Ez-B I need to upgrade it ? "
Sorry, I think I'll hybrid my setup and use an old version of EZ-B with a small 1.2 Gig laptop just to run some rudimentary flashy lights and maybe ping and use an Atom Bot Board with a Serial servo Controller for servo control.
I'm not totally green at this but just seem to be stalled on having to use a 4 gig memory , 2 gig or faster Cpu computer just to read some pings etc and move some servo's when I have and use a Hexapod robot that has wireless vision, sonar, 6 - 3DOF legs ( with inverse kinematics ) , wireless serial connections and can run with or without a PC.
Obviously the vision needs a pc for processing and i do that with Robot-Realm on a 1 gig cpu, 1 gig memory laptop running XP Pro with serial wireless connection.
The Hexapod does not need a pc to function autonomously and can actually "see" with an ir sensor when not using camera vision.
This all runs on a Basic Atom Botboard with these specs
32K of Program Space 2000 (2K) Bytes of User / System RAM Up to 8 A/D pins Up to 100,000 Plus BASIC Instruction Per Second Code and Pin compatible to the Basic ATOM Hardware based 32 bit math Hardware PWM Hardware UART Hardware SPI and I2C Based on a true 32 bit processor
now you may see why I'm bucking the EZ-B / PC method don't get me wrong the EZ-B is a great peripheral for the modern PC but the ARC program is the main story here that I'm beating my brain about.
What I'm saying is, the more advanced things you can do with ARC may push that system beyond it's limits. Processing sensor data with complex algorithms or image processing can be a resource hog for instance.
The camera control has been re-written recently and works much smoother but it's still going to require some processing power.
To "just read some pings and move some servos" will not require much processing power. But your original post was about using the camera, not the ultrasonic sensors.
#15
Indirectly i still am still referring to vision....get pings, turn camera, have a-look, process info, run a couple servo's or motor control, as you say thou the processing part is what needs the power.
#16
Ya i thought it worked better on XP before also.
My thing is , do i want to stick a high end laptop on a wheelchair robot that will be in the real world and when something blows ( and it will ) shell out another $500 dollar bill.
If my bots brain was stationary well no prob i use an AMD 6 core , 4 monitor machine, but it's not and i'm trying to use the least expensive with the most power needed to operate the EZ-B.
Anyhow we can hash this subject forever and thanks for all the input , now back to hacking the bot.
