Camera Tracking Direction
hi ! DJ
Now, I am trying the tracking operation, This time i set the tracking red Color ball and every thing is all right except the bad direction . if red ball move to right servo move a left so different direction !? my robot head move opposite direction , So in Camera Config I change the invert direction
CHECK BOX on . but at that time servo is not move well, and did not move normally , if the camera up side down servo move normally , but video image is also up side down , So , I could not change this bad situation . Please help me how to move normal direction of servo.
If the servos move the wrong way tick (or untick) the invert direction option(s). If it moves left when it should move right toggle the invert direction option for the X axis If it moves up when it should move down toggle the invert direction option for the Y axis
dear Rich
thank you for your advise
but I have already use x Axis the invert direction but if i set it servo move right and left quickly so i do not understand the reason why ?
Check horizontal increment if it's moving too quickly or by too much.
The invert direction only inverts direct. If it's moving the wrong direction you need to toggle the setting (i.e. if it was on turn it off, if it was off turn it on). It does not affect the speed of the movement.
Also check the minimum and maximum positions and make sure they are around the right way (lowest number in minimum and highest in maximum)
