Smart Variable Watcher icon Smart Variable Watcher — Efficient ARC Variable Watcher - lower CPU for large projects; slow initial array render but faster updates; shows name, type, value, length Try it →
We are trying to get a video stream of the Roli's camera in the "Capture Element" which is like a display panel.
My question is if there is anyway we can find the robot's camera as a device.
using System;
using System.Collections.Generic;
using System.IO;
using System.Linq;
using System.Runtime.InteropServices.WindowsRuntime;
using Windows.Foundation;
using Windows.Foundation.Collections;
using Windows.UI.Xaml;
using Windows.UI.Xaml.Controls;
using Windows.UI.Xaml.Controls.Primitives;
using Windows.UI.Xaml.Data;
using Windows.UI.Xaml.Input;
using Windows.UI.Xaml.Media;
using Windows.UI.Xaml.Navigation;
using Windows.Media.Capture;
using Windows.Storage;
using Windows.Devices.Enumeration;
using System.Threading.Tasks;         // Used to implement asynchronous methods
using Windows.Devices.Sensors;        // Orientation sensor is used to rotate the camera preview
using Windows.Graphics.Display;       // Used to determine the display orientation
using Windows.Graphics.Imaging;       // Used for encoding captured images
using Windows.Media;                  // Provides SystemMediaTransportControls
using Windows.Media.MediaProperties;  // Used for photo and video encoding
using Windows.Storage.FileProperties; // Used for image file encoding
using Windows.Storage.Streams;        // General file I/O
using Windows.System.Display;         // Used to keep the screen awake during preview and capture
using Windows.UI.Core;                // Used for updating UI from within async operations
using System.Diagnostics;
// The Blank Page item template is documented at https://go.microsoft.com/fwlink/?LinkId=402352&clcid=0x409
namespace EZ_B
    /// An empty page that can be used on its own or navigated to within a Frame.
    public sealed partial class MainPage : Page
        EZB _ezb;
        EZBv4Video video;
        MediaCapture _mediaCapture;
        bool _isInitialized;
        bool _isPreviewing;
        bool _isRecording;
        bool _externalCamera;
        bool _mirroringPreview;
        private readonly DisplayRequest _displayRequest = new DisplayRequest();
        private readonly DisplayInformation _displayInformation = DisplayInformation.GetForCurrentView();
        private DisplayOrientations _displayOrientation = DisplayOrientations.Portrait;
        private readonly SimpleOrientationSensor _orientationSensor = SimpleOrientationSensor.GetDefault();
        private SimpleOrientation _deviceOrientation = SimpleOrientation.NotRotated;
        private static readonly Guid RotationKey = new Guid("C380465D-2271-428C-9B83-ECEA3B4A85C1");
        bool flag;
        public MainPage()
            this.InitializeComponent();
        //ASYNC IS REALLY IMPORTANT//////////////////
        private async void Button_Click(object sender, RoutedEventArgs e)
            if ((Button)sender == inputButton)
                _ezb = new EZB();
                flag = true;
                //AWAIT IS REALLY IMPORTANT//////////////////
                await _ezb.Connect("192.168.1.1");
                if (!_ezb.IsConnected)
                    greetingOutput.Text = "NOT CONNECTED!";
                    return;
                if (_ezb.IsConnected)
                    greetingOutput.Text = "CONNECTED!";
                    MusicSynth m = new MusicSynth(_ezb);
                    m.PlayNote(MusicSynth.NotesEnum.C1, 1000);
                    //CAMERA
                    //CameraCaptureUI ui = new CameraCaptureUI();
                    video = new EZBv4Video();
                    await video.Start(_ezb, "192.168.1.1", 23);
                    video.CameraSetting(EZBv4Video.CameraSettingsEnum.Res320x240);
                    video.CameraSetting(EZBv4Video.CameraSettingsEnum.START);
                    await InitializeCameraAsync();
            return;
        private async Task InitializeCameraAsync()
            if (_mediaCapture == null)
                // Get available devices for capturing pictures
                var allVideoDevices = await DeviceInformation.FindAllAsync(DeviceClass.VideoCapture);
                // Get the desired camera by panel
                DeviceInformation cameraDevice =
                    allVideoDevices.FirstOrDefault(x => x.EnclosureLocation != null &&
                    x.EnclosureLocation.Panel == Windows.Devices.Enumeration.Panel.Back);
                // If there is no camera on the specified panel, get any camera
                cameraDevice = cameraDevice ? allVideoDevices.FirstOrDefault();
                if (cameraDevice == null)
                    greetingOutput.Text = "No camera device found.";
                    return;
                // Create MediaCapture and its settings
                _mediaCapture = new MediaCapture();
                // Register for a notification when video recording has reached the maximum time and when something goes wrong
                //_mediaCapture.RecordLimitationExceeded += MediaCapture_RecordLimitationExceeded;
                var mediaInitSettings = new MediaCaptureInitializationSettings { VideoDeviceId = cameraDevice.Id };
                // Initialize MediaCapture
                try
                    await _mediaCapture.InitializeAsync(mediaInitSettings);
                    _isInitialized = true;
                catch (UnauthorizedAccessException)
                    greetingOutput.Text = "The app was denied access to the camera";
                catch (Exception ex)
                    Debug.WriteLine("Exception when initializing MediaCapture with {0}: {1}", cameraDevice.Id, ex.ToString());
                // If initialization succeeded, start the preview
                if (_isInitialized)
                    // Figure out where the camera is located
                    if (cameraDevice.EnclosureLocation == null || cameraDevice.EnclosureLocation.Panel == Windows.Devices.Enumeration.Panel.Unknown)
                        // No information on the location of the camera, assume it's an external camera, not integrated on the device
                        _externalCamera = true;
                    else
                        // Camera is fixed on the device
                        _externalCamera = false;
                        // Only mirror the preview if the camera is on the front panel
                        _mirroringPreview = (cameraDevice.EnclosureLocation.Panel == Windows.Devices.Enumeration.Panel.Front);
                    await StartPreviewAsync();
                    //UpdateCaptureControls();
        private async Task StartPreviewAsync()
            // Prevent the device from sleeping while the preview is running
            _displayRequest.RequestActive();
            // Set the preview source in the UI and mirror it if necessary
            PreviewControl.Source = _mediaCapture;
            PreviewControl.FlowDirection = _mirroringPreview ? FlowDirection.RightToLeft : FlowDirection.LeftToRight;
            // Start the preview
            try
                await _mediaCapture.StartPreviewAsync();
                _isPreviewing = true;
                Debug.WriteLine("Exception when starting the preview: {0}", ex.ToString());
            // Initialize the preview to the current orientation
            //if (_isPreviewing)
            //    await SetPreviewRotationAsync();
The camera is not a device because it is not connected to the computer through any ports. It is wifi and a data steam.
The uwp source code provides example to view the camera.
What additional functionality are you looking for?
First of all, thank you for replying to this email. This is one of the late night thing we are doing, and we kind of posted this in a hurry.
Do you know which UWP source code is it? We had problems using and running the UniversalBot project and had to manually add the classes. We probably missed it along the process.
The file is called "EZBv4Video.cs"
The "OnImageDataReady" event will be raised for every new frame. The data in the OnImageDataReady event is a jpeg byte array.
We tried running the UWP source code (UniversalBot), but for some reason it would not event handle or manage the event "OnImageDataReady."
We have also tried making our own codes, and decoding the jpeg into bitmap, so that we can use the ImageSource using XAML. Unfortunately, it did not work, and we are not sure if the event "OnImageDataReady" is actually being raised.
This is the last part of the puzzle that we need for our research, and we are kind of desperate.
The codes are attached below.
namespace EZ_B
        EZB _ezb;
        EZBv4Video _video;
        WriteableBitmap bm;
        DispatcherTimer _timer = new DispatcherTimer();
        public MainPage()
            _timer.Interval = TimeSpan.FromMilliseconds(500);
            _timer.Tick += _timer_Tick;
            if ((Button)sender == connectButton)
                _ezb = new EZB();
                    connectStatus.Text = "NOT CONNECTED!";
                    return;
                     _timer.Start();
                    connectStatus.Text = "CONNECTED!";
                    _video = new EZBv4Video();
                    _video.OnImageDataReady += Video_OnImageDataReady;
                    await _video.Start(_ezb, _ezb.ConnectedEndPointAddress, 24);
                    _video.OnStart += Video_OnStart;
                    _video.CameraSetting(EZBv4Video.CameraSettingsEnum.Res640x480);
                    //_video.CameraSetting(EZBv4Video.CameraSettingsEnum.START);
                    if (_video.IsRunning)
                        cameraStatus.Text = "CAMERA STREAMING!";
                    else
                        cameraStatus.Text = "CAMERA NOT STREAMING!";
            return;
        //end of Button_Click
        private async void Video_OnImageDataReady(byte[] imageData)
            tappedStatus.Text = "OnIMAGE!";
            await Dispatcher.RunAsync(
            Windows.UI.Core.CoreDispatcherPriority.Normal,
            async () =>
                MemoryStream ms = new MemoryStream(imageData);
                var decoder = await BitmapDecoder.CreateAsync(BitmapDecoder.JpegDecoderId, ms.AsRandomAccessStream());
                var sbit = await decoder.GetSoftwareBitmapAsync();
                bm = new WriteableBitmap((int)decoder.PixelWidth, (int)decoder.PixelHeight);
                sbit.CopyToBuffer(bm.PixelBuffer);
                imageSource.Source = bm;
//////////////////////////////////////commented out
            //await Dispatcher.RunAsync(Windows.UI.Core.CoreDispatcherPriority.Normal, () =>
            //    imageSource.Source = (BitmapSource)imageData.AsBuffer();
        private  void Video_OnStart()
            tappedStatus.Text = "OnStart!";
        private async void _timer_Tick(Object sender, Object e)
            tappedStatus.Text = string.Format("ADC 0: {0}", await _ezb.ADC.GetADCValue12Bit(EZ_B.ADC.ADCPortEnum.ADC0));
<Page
    x:Class="EZ_B.MainPage"
    xmlns="https://schemas.microsoft.com/winfx/2006/xaml/presentation";
    xmlns:x="https://schemas.microsoft.com/winfx/2006/xaml";
    xmlns:local="using:EZ_B"
    xmlns:d="https://schemas.microsoft.com/expression/blend/2008";
    xmlns:mc="https://schemas.openxmlformats.org/markup-compatibility/2006";
    mc:Ignorable="d">
    <StackPanel Background="{ThemeResource ApplicationPageBackgroundThemeBrush}" Margin="0,20,0,0">
        <Button x:Name="connectButton" Content="Connect" Click="Button_Click"/>
        <TextBlock x:Name="connectStatus"/>
        <TextBlock x:Name="cameraStatus"/>
        <TextBlock x:Name="tappedStatus"/>
        <Image x:Name = "imageSource" Width ="200" Height="200" Visibility= "Visible" Stretch="Fill" />
    </StackPanel>
</Page>
Please properly format your code when pasting in the forum. There are UBB CODE legend directly to the right of the input form.
  1. Add a breakpoint in the event.
  2. The assignment of the OnStart event is after you start the camera...
  3. Do not set camera settings until you actually get a camera to work
  4. Check the _ezb.GetLastErrorMsg to see if the camera is actually connecting
The code should be...
I am confused on when the camera actually starts.
The camera starts when you execute the method _camera.Start();
The issue is going to be clear once you follow my directions. Please review my previous response.
