I noticed lately when I use the Camera, tracking only last "one" time, whether it is face, color or whatever.
How can I deleted the camera and re-install it?
EzAng
Openai Text To Speech
— Convert text to dynamic, real-time speech with nine expressive OpenAI voices-natural, varied, accessible robot communication.
EzAng
Hmmm I haven't been experiencing this. What seems to happen? With any tracking type once the object is detected the camera skill crashes?
I don't think you need to uninstall the camera. Is it a camera that you have just installed or have you been using it for a while? I'm just trying to determine if anything has changed with your setup.
Do you have the latest version of ARC installed?
I have the latest version of ARC - later I can try another camera
I tried my computer camera and Ez B Camera thanks
EzAng
So Jeremie, I just got back, what should I do?
EzAng
If you could answer the first few questions I had in my first post that’d help me out
I need more info on what’s happening actually happening.
Wish we can speck, I will try the JD robot next.
ok, when I use the EZ-B v4 Camera, tracking, with an IoTiny
it only tracks once, then all the tracking boxes are empty - look below, I had it on face, then color, same thing happens, this just started.
I use DJ code:
here is the debug info: 2020/09/03 16:00:27 -05:00 - Attempting connection on 192.168.1.12:23 2020/09/03 16:00:27 -05:00 - Connected to 192.168.1.12:23 2020/09/03 16:00:27 -05:00 - Reports EZB v4 OS IoTiny 2020/09/03 16:00:27 -05:00 - Firmware 'EZ-Robot IoTiny standard firmware' on 'EZ-Robot EZ-B IoTiny' supports the following capabilities:
Broadcasts to ARC's PnP network scanner 2020/09/03 16:00:27 -05:00 - EZ-Robot IoTiny standard firmware ID: 222-222-222-222-222-222-222-222-222-222-222-222 2020/09/03 16:00:27 -05:00 - Setting battery monitor voltage: 7 2020/09/03 16:00:27 -05:00 - Setting battery protection: True 2020/09/03 16:00:27 -05:00 - Setting i2c rate: 100000 2020/09/03 16:00:27 -05:00 - EZ-B voltage is 8.211534684 2020/09/03 16:00:27 -05:00 - EZ-B temperature is 25.02440624839843800C 2020/09/03 16:00:27 -05:00 - Connected 2020/09/03 16:00:36 -05:00 - Camera Initialized: EZB://192.168.1.12:24 @ 320x240
I downloaded ARC again, did repair, no luck
Like I said, I will try the JD robot next., Tested JD robot, same thing happens,
I deleted Arc, fresh install - same thing
any ideas?
thanks EzAng
@Ezang:
this:
translates to:
Basically WaitForFace blocky enables the cameraFaceTracking and then disables cameraFaceTracking
you can store the previous state i.e. before the WaitForFace and then set after the block
I believe is a design choice.
I assumed CameraTrackingType was the configuration setting but is not. So I believe the solution is to have a global variable to set/store the tracking state and then restore the state after the WaitForFace.
I tried it, no luck
EzAng
