Camera Snapshot icon Camera Snapshot — Save camera snapshots to 'My Robot Pictures' (Pictures folder), manual or timed (0-100s), and trigger programmatically via controlCommand. Try it →
Grid settings are on the bug list.
Ok, Thanks:) I can see you guys at EZ-Robot are right on the job! :D
There are no reported bugs or issues with servo speed. What problems are you having?
Hi DJ, I had also mentioned this grid line question awhile ago, so if you are working on it, it would be nice to be able to set to grid lines to a certain setting with a command control or save the settings in a script. That way grid lines that need to be set at other than default settings would automatically adjust when the script is run.
Thanks
The grid lines have been in the to-do list. Nothing ever leaves the todo list
Did you mean to say " nothing ever leaves the todo list until it is done" ? Just kidding. Thanks DJ Go Flames Go!
