Roll Pitch Yaw icon Roll Pitch Yaw — Rotate and position camera or object with roll/pitch/yaw controls; save camera settings; bind or monitor a 3-value EZ-Script array for live rotation. Try it →
Resolved Resolved by Athena!
Can ARC work with an Lattepanda/Arduino with a PCA9685 connected to it?
Can ARC Work With An Lattepanda/Arduino With A PCA9685 Connected To It?
Can ARC work with a Lattepanda's Arduino with DJ's firmware installed with a PCA9685 connected to it to control servo's in the following connection model?  Note UNO represents the Lattepanda's Arduino GPIO.
I would be connecting to pin 6 for A4 and pin 8 for A5
Will the standard servo skills work in ARC if ARC is connected to the Arduino or is something else needed? Like the PCA9685 16-Channel PWM Driver Module Library loaded on the the Arduino?
Lattepanda by DF Robot
LattePanda with Synthiam ARCx runs headless, loads EZB firmware on the built-in Arduino, and controls robots from any browser
Servos 12
UART 1
ADC 5
Digital 12
#17   — Edited
DJ,  I compiled the package you created and uploaded it to the Lattepanda.  When I set it up in ARC using 57600 Baud with RTS checked and setup the Vertical servo control when I go to pick the port it show a picture of the PCA9685 and I set port 1 which is the port on the board I am using I get no servo Movement.
I connected GND to 23 and VCC to Pin 24.  SDA was to Pin 6 and SCL was to Pin 8.  Note also tried these on Pins 17=A4,19=A5 had the same issue.
The following is a video of what happening when I move the value in the servo control in ARC
https://www.youtube.com/shorts/cBHq1bp8d7Q
#19   — Edited
DJ Yes I did to the letter.   But I have to tell you his changes don't make sense to me.  Because nowhere else in the code are you using pca9685
#20
DJ, this post was in the right place under "16 servo Shield by Adafruit"  What I was asking was because your "EZ-Genuino_Uno_Adafruit_16_Servo_Shield.zip (Dec 11, 2022)" firmware looks to be based off of the same code in the "EZ-Genuino_Leonardo.zip (updated Dec 11, 2022)" firmware that has dummy code for Serial1 and Serial2 for defensive coding if it should be added to the "EZ-Genuino_Uno_Adafruit_16_Servo_Shield.zip (Dec 11, 2022)" to make it more robust.
Also your "EZ-Genuino_Uno_Adafruit_16_Servo_Shield.zip (Dec 11, 2022)" firmware does not work for port 0 and Port 1 on the controller because you have: #define _PortStart 2  and it should be #define _PortStart 0
I had attach the zip file with my changes to the other post for your review.  If you don't feel I am right it's all good was just trying to help.
#21   — Edited
Removed as no longer needed.
#22
Here are the changes I posted in the other post for your review.
EZ-Genuino_Uno_Adafruit_16_Servo_Shield-SMM.zip
I removed a few of my comments in the other post because it is clear people did not understand them.  I hope at this point you are clear on what I was trying to convey to you.
#23
Good work getting your pca9685 (not the supported Adafruit board) working. I'll post the code. I won't name it 16-channel adafruit as it uses a generic controller and not the adafruit version - it might help others with generic knockoffs as well
#24
I am happy we are on the same page now.  Just a note I also tested this on the Lattepanda and it also works.
