Virtual Robot icon Virtual Robot — Display robot image with real-time servo position readouts and basic servo management including servo deletion Try it →
Can Ezb Read Pwm Values Like The Echo Pin On A Sonar
I guess this is another question for the great DJ I very common TSOP4840 IR receiver and output is PWM and need read the value and there is 4 of them i am using. so looking at the ECHO PIN can it work and any script for it
Also the trigger pin on sonar i want to pulse the IR transmitter using PWM control in the interface you have for it I know others looking at the same idea for low cost home base docking
From the EZ-Script manual
Quote:
GetPWM (digitalPort) Gets the PWM (Pulse Width Modulation) of specified port PWM is between 0 and 100 Example: $x = GetPWM(D14)
wow GREAT i need to try it,might be a low cost idea for beacon design
