Sabertooth Kangaroo icon Sabertooth Kangaroo — Movement panel enabling Kangaroo & Sabertooth encoder-based speed/velocity control, UART/PC serial options, tuning and encoder setup. Try it →
Unless someone knows if it can be done from inside the ARC file then the answer is no. tired
asfaik: No ARC option.
The alternative:
  1. Backup the project file, if somethings goes wrong you have the backup.
  2. Open the project file with Windows Notepad.
  3. Use Menu Edit > Replace... Find what: <Title>Notepad</Title> Replace with: <Title>My custom name</Title>
Replacing 3 notepads:
Note 1: The project file is a Xml document: 1.1) xml tags e.g. Title are case sensitive, preserve the original case 1.2) xml tags are closed with "/", don't forget </Title> closes the <Title>
Note 2: Use only letters, numbers, underscore and space between <Title></Title>
Note 3: ARC uses the control name i.e. text between the <Title></Title> to identify the control. Keep each control i.e. Notepad with an unique name.
Great Thanks again ptp!
