Speech Synthesis icon Speech Synthesis — Speak user-defined text via PC audio or EZ-B v4 speaker; configurable voices, effects and speed; uses Windows TTS; programmatically callable. Try it →
You can't.
Just be sure of your post before posting:).
Well, I had asked a question then figured it out, so your saying there is no way to delete them?
We do not allow deletion of posts. Every question that is asked helps others with the same question. We do not want people removing their questions because sharing is an important way of learning.
The search feature is an important asset to find information. There are thousands of posts, and nearly every question has already been asked:)
Nope. A forum moderator may delete it when one comes on but you are unable to
You can't delete your thread post but you can edit your post after it is submitted. You might want to add to your original statement like (Found Solution!) or other words describing your solution.
To Edit a post that you have created just select the Edit block located just above and to the right of your posted text.
Ok, thanks for the update guys, I appreciate it.
