Omron HVC-P icon Omron HVC-P — Omron HVC-P ARC plugin: real-time body, hand, face, gaze, gender, age, expression and eye estimation; facial recognition via Omron software Try it →
Movement panel is for the movement of your robot. Like driving a direction by wheels or flying. If you want to control servos, uncheck the "use movement panel" and select the servos for the X and Y axis. You can do the same for the second joystick also.:)
Okay, thanks.
I still have the problem of controlling 5 servos from a single from a single (or double) joystick.
I was hoping I could use the joystick buttons to switch what the joystick controls.
Is this an option? I guess I could use the buttons for servo triggers instead of mode triggers.
You won't be able to control 5 with 4 axis. You can control 1 servo per joystick axis, unless you use the Relative servo Control. The relative servo Control will allow you to have servos move relative to another servo.
I assign buttons to move servos when i need to move more. For example the arms of a robot. I'll use one joystick for movement, second joystick for head. and buttons for arms.
Using the commands ServoUp(port, value) and ServoDown(port, value)
Okay great, that should work out just fine then:)
